Ssangyong Musso Advanced Light Control System
Mensaje Ssangyong Musso Advanced Light Control System
Buscando videos nuevos de Musso en Youtube me encontré con esto, por lo que vi (no lei nada) hay un control para las luces de giro y balizas, se activa el giro por unos seg. en forma electrónica para cambio de carriles por ej. o se interrumpe las balizas para poner un giro. En la descripción dice los siguiente:
Ssangyong Musso implement an Advanced Light Control System,
SDHF (Smart Directional & Hazard Flasher) and AEBS (Active Emergency Brake light System).
The most kind of Vehicles can have new function by install with SDHF&AEBS, This advanced light control system had implemented in Ssangyong Chairman REXTON ACTYON STAVIC, TOYOTA Wish CAMRY, Hyundai TERRACAN Matrix, HONDA ACCORD CR-V, NISSAN SENTRA X-Tril Teana, Mitsubishi Galant Spacegear, Mazda MPV Tribute 5,Ford Escape ....etc.
Link
Sistema de adventencia al abrir la puerta
Door open alert function by SDHF
The hazard signal will turn on automatically when driver or passenger open the door.
Link
Otro sistema que muestra es uno para las luces de stop, actúan diferente según sea el tipo de frenada para llamar la atención
Active Emergency Brake light System.
The notion of the emergency brake light reacte when the velocity decelerate is reach 7 M/Sec2. On actual road driving, It's not a good notion by detecting the whole vehicle's G-force or inertia, because the type of vehicle small, big, type M, N...., loading, road situation, up/down hill, friction between tire & road, brake system strength and so on, all these factors will cause emergency signal reaction timing incorrectly, it is could be late even can not to alert the following vehicle when really needed. 7 M/Sec2 is not absolute correct, so other point 6 or 4 M/Sec2 had issued by different manufactures.
AEBS is an advance alert system, by detecting driver step on brake pedal behavior,when the driver to step on brake pedal deep and rapid, the AEBS will indicat flashing light signal to warning the following driver, avoid rear-end collision effectively.
This Musso installed with AEBS-2.
Link
Link
Interesante ¿no?
Mensaje Re: Ssangyong Musso Advanced Light Control System
MUY BUENO PABLO   ,SERA COMPLICADO EL CABLEADO
Saludos Jorge
MUY BUENO PABLO ME GUSTAN LOS DOS SISTEMAS ESTA BARBARO!,ADEMAS DE AVISAR QUE ES UNA FRENADA BRUSCA QUEDA HACIENDO BALIZA PARA AVISAR QUE QUEDÓ DETENIDO    ...
Saludos Walter
ME ENCANTO EL DE LA FRENADA. SE CONSEGUIRA ALGO POR ACA?
CHE, TA BUENISIMO ESTE SISTEMA, Y PORQUE NOSOTROS NO LO TENEMOS?
SERA PORQUE SOMOS ARGENTOS???
"LA BESTIA QUE SE RECIBIO DE TREPADORA EN RAMALLO"
Hay autos que lo tienen, quiza nosotros no tenemos ESE sitema en nuestras Mussos, por el modelo.
Igual en la primera no me gusto el ruido a "comiendo papas fritas " y la musica romantica, porque  es como que las dos cosas no van
Y cuando muestran las luces de freno, el Sr. no es amable. Asi que si no tenemos esa tecnologia, de todas maneras sabemos ser romanticos y creo que los argentinos son mas caballeros
No tiene nada que ver pero no importa
VISTE QUE YO SABIA !!!!!! Tenian que ser PAPAS FRITAS !!!!
Image Image Image ImageImage
No hay nuevos mensajes Ssangyong Musso marckito73 PRESENTARSE Y CONOCERNOS 2 Lunes, 10 Agosto 2015, 9:50 Ver último mensaje
No hay nuevos mensajes Repuestos De Musso Ssangyong Tito Bariloche TEMAS GENERALES DEL GRUPO 17 Jueves, 03 Junio 2010, 21:28 Ver último mensaje
guiwa5
No hay nuevos mensajes Ssangyong Musso Tonilitio Invitado FOTOS Y VIDEOS 6 Sábado, 18 Agosto 2012, 15:01 Ver último mensaje
soyjub
El tema está bloqueado: no pueden editarse ni agregar mensajes. Ssangyong Musso 602 TDi Automática alejandro TEMAS GENERALES DEL GRUPO 1 Lunes, 10 Septiembre 2007, 12:45 Ver último mensaje
No hay nuevos mensajes Colores Cables En Ssangyong Musso. Oskirri ELECTRICIDAD 5 Jueves, 26 Marzo 2015, 19:04 Ver último mensaje
Oskirri
