Asunto: PIEZAS O PARTES
QUE FUNCION TIENEN ESTAS PIEZAS ESTAN DEBAJO DEL TIMON LADO DERECHO
Y ESTE INTERRUPTOR PARA QUE SIRVE ESTA ARRIBA DE LA CAJA DE FUSIBLES
Asunto: Re: PIEZAS O PARTES
HABER LOS QUE SABEN !!!! ACÁ VAMOS A APRENDER ALGO. :clap: :clap: :clap:
:p :p
Acá el que sabe es "San Google" :-p
Yo sospechaba para que era, pero lo confirmé en Ssangyong Motors, parecía una compu y era momas. :eek:
Super Time Interrelated Control System (STICS)
It is the device that the microcomputer automatically controls the various warnings and notices for driver’s perception with easy and is consisted of various warning lights and waning alarms.
Starting Key Hall Lighting.
If open the door on driver’s side, the lamp of starting key is automatically lighted for easy looking of starting key at night driving.
Sensitization Type Room Lamp
It is automatically lighted on when open the door and slowly off when close the door for convenience.
Starting Key Reminder
If open the door without taking stating key out, warning alarm signals intermittently.
Central Locking Device
It is convenient and secures safety driving because if close the door on driver’s side, then the door on passenger’s side is also locked.
Automatic Door Lock
When it reaches at the certain speed, it atomically locks the door for safety driving.
:-k La otra llavesita ni idea, es algo casero, puede estar relacionado con la alarma o alguna otra cosa, tendrás que seguir los cables a ver donde te lleva.
LA FOTO DE LA LLAVE ,TENES UN ZOCALO VACIO TE FALTA UN RELE QUIZAS PUSIERON ESA LLAVE PARA ACCIONAR MANUALMENTE AUNQUE PARA MI ES DE LA ALARMA COMO DICE PABLO
SEGURAMENTE DEBE SER ALARMA NO CREO QUE SEA OTRA COSA
PABLO QUE MIE..... DICE AHI??? :mrgreen: :mrgreen: :mrgreen:
ESTÁ CLARITO , PARA UN BESTIA COMO YO NO" :shock: :p :p
Walter, en pocas palabras esa cajita es una compu que controla varias advertencias, entre otras...
La luz que se enciende donde entra la llave de contacto
Apaga la luz de cortesía en forma "soft", no se apaga cuando cerras la puerta sino que luego de unos segundos en forma gradual.
Alarma de llaves puestas cuando abris la puerta.
Control de cierre de puertas cuando se cierra la del conductor.
Automatic Door Lock
Cierra las puertas automáticamente al llegar a una cierta velocidad.
ahhhh así pos sí :mrgreen:
justo lo que buscaba, esa luz de la llave no me funciona ,bueno me di cuenta que estaba porque encendió no se en que momento en un color verde, tengo kilombo con centralizado , así que me parece que viene todo de ahi :-k
gracias pablo te mando un abrazo :p :p
jua jua jua jua :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: son varios los que estuvieron brindando ??? :beer: :beer: :beer:
:-p :-p :-p :-p
Página generada en:: 0.1187s (PHP: 31% SQL: 69%)
