Ir a la página Anterior  1, 2
Asunto: Re: MI QUERIDO VISCOSO
Gracias Daniel, justamente había un comentario en este post sobre la diferencia de los códigos y el vendedor le había dicho que era el contenido del envase, haciendo referencia a la cantidad de aceite que trae :roll:
:beer:
qwerty126 escribió: [Ver mensaje]
Dado ya hay varios en el club que sufren de recalentadas cuando exigen el motor en trepadas (mi caso), me fui a una casa de repuestos toyota y pregunte por el liquido del viscoso, el que me atendió me dijo que cualquiera de los codigos (08816-03001 , 08816-06001, 08816-10001) eran lo mismo. Como no me quedé conforme busqué y encontré lo siguiente:
The part numbers are 08816-03001 (3,000 Cst), 08816-06001 (6,000 Cst), and 08816-10001 (10,000 Cst), respectively.
The higher the Cst number is, the stronger the clutch engagement will be (i.e. it will spin faster when it engages at appropriately high temperature ~ 100 C)/
A stokes (St) is a unit of kinematic viscosity. One centistokes (cSt)
is 1/100 of a stokes. FYI, water is ~ 1 cSt, so the 3,000 Cst silicon fluid is 3000 times more "denser" than water.
For synthetic engine oils with 10W-30 weight, they usually have a kinematic viscosity of about 60 cSt at 40°C and 10 cSt at 100°C. So you see that these fan clutch silicone fluids are so much more viscous than engine oils.
Also, silicone fluid is not subject to viscosity degradation while the viscosity of engine oils, gear oils etc... is very much dependent upon temperature, and is subject to viscosity breakdown due to high temperature and shear stress, because their VII (viscosity Index Improvers) are simply added polymers (long chains of molecules. So fan clutches use silicone fluids for 2 major reasons:
1) They inherently have very high kinematic viscosity.
2) They are not (or only very negligibly) subject to viscosity degradation.
Interesante no?
Citar:
Los números de parte son 08816-03001 (3.000 Cst), 08816-06001 (6.000 Cst) y 08816-10001 (10.000 Cst), respectivamente.
A mayor número de Cst, mas duro se pone el embrague viscoso.
Un Stokes (St) es una unidad de viscosidad cinemática. Una centistokes (cSt)
es 1 / 100 de un Stokes. Por ejemplo, el agua es apróximadamente 1 cSt, por lo que un fluido de 3000 Cst será 3000 veces más "denso" que el agua.
Los Aceites sintéticos para motor 10W-30, suelen tener una viscosidad cinemática de 60 cSt a 40 ° C y 10 cSt a 100 ° C. Así que se puede ver que estos fluidos de silicona para embrague viscoso son mucho más viscosos que los aceites de motor.
Además, el fluido de silicona no está sujeto a la degradación de la viscosidad, mientras que la viscosidad de los aceites de motor, de transmisión mecánica aceites etc .. es muy dependiente de la temperatura, y está sujeto a ruptura de viscosidad debido a la alta temperatura y el estrés de cizalla, puesto que su VII (Índice Mejorantes viscosidad) son simplemente por el añadido de polímeros (largas cadenas de moléculas. Por lo tanto, el uso del ventilador embragues fluidos de silicona por 2 razones principales:
1) Ellos sí tienen muy alta viscosidad cinemática.
2) No están (o sólo muy insignificante), sujetos a la degradación de la viscosidad.
Asunto: Problemas Con El Viscoso
buenas a todos les comento que despues de mucho tiempo e tenido problemas con la temperatura de mu musso.
bueno la cosa es que el viscoso estaba re blandito y no tira casi nada.
para los que no estan enterados el viscoso funciona con un aceite de silicona que produce un arrastre entre dos superficien y asi nuestro radiador se refrijera.
en mi camioneta esto no estaba pasando.
yo le cargue aceite a mi viscoso y ahora anda re bien
les comento que es muy facil de hacer.
lo que hice fue hacer un aujerito de 3.5 milimetros en una de las paredes del viscoso y le cargue aceite por este orificio luego rosque y lepuse un tornillo como tapon y listo trabajo terminado.
bueno cuesta mucho que el aceite pase por que es muy viscoso y toma un tiempo largo pero es facil de hacer.
si a alguien le interesa tengo unas cuantas fotos del trabajo
Asunto: Re: Problemas Con El Viscoso
Seguro suma, asi que bajalas nomas :eek:
BUI escribió: [Ver mensaje]
Ya que tenes fotos ponelas nomas :eek:a muchos nos ba a venir bien :eek:
fijate los primeros post .-
lo que hice fue hacer un aujerito de 3.5 milimetros en una de las paredes del viscoso y le cargue aceite por este orificio luego rosque y le puse un tornillo como tapon y listo trabajo terminado.
es aceite de toyota :eek: y tenes los enlaces con fotos de esta reparación en el primer mensaje
Asunto: Para Tener En Cuenta... Antes De La Reparación De Viscoso
Si no tiene mas liquido viscoso es porque hay una fuga.
si no se repara la fuga lo que pongamos tambien se fugara.. ( valga la redundancia)
tambien puede ser desgaste de los elementos internos.
considerar bien antes de comprar los elementos que no son baratos...
Página generada en:: 0.0767s (PHP: 44% SQL: 56%)
